Importing PDF Scale Problem
JEFFJW9BB
JEFFJW9BB
Hello, My first pdf import.
The scale of the original drawing that was PDF'd is 1/4" = 1'-0", I set the scale for this drawing at 1/4" = 1'-0" . The import scale was 1.00.
When I draw a line it is full scale, I can't draw at 1/4" scale.
Drawing attached.
I would very much appreciate any help!
maxim_k
Hi @JEFFJW9BB ,
The scale you set is the annotation scale, it only affects the annotation scale - text size, linetype and hatch scale, and so on.
If you need to draw at 1/4" scale, you need to scale all geometry in your drawing at 1/4 scale.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
JEFFJW9BB
Thank you for your reply.
I select all geometry then use the SCALE command.  I thought to go from 1:1 to 1/4 scale the scale factor would be 0.25 but no.  I tried the inverse, 4, and it got bigger, good, but not correct.  How do you calculate the scale factor to go from 1:1 to 1/4" = 1'-0"?
JEFFJW9BB
I googled around and found that the scale factor is 48.  It worked!
Thank you so much for your valuable assistance!
JEFFJW9BB
Thank you!
maxim_k
Yes:
1/4" = 1'-0"
0.25 : 12
1 : 48
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
