Hi @camille_bobeau ,
You can use -LAYER command to export layer state to .LAS file.
Here are the command options you use (I assume that you need to export "test" layer state):
Command: -LA -LAYER
Current layer: "Defpoints"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: A
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: EX
Enter name of layer state to export or [?]: test
Export state to file name <test>: ~ <- tilde gives you an option to open "Save as" dialog
Now you can import saved layer state to any drawing with the same -LAYER command:
Command: -LA
-LAYER
Current layer: "0"
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: I
Enter file name to import <Drawing1>: ~ <- tilde gives you an option to open "Open file" dialog
Restore could not restore all line types.
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: R
Enter name of layer state to restore or [?]: test
>>>>My goal is merely to copy paste it in a text box
You can also open .LAS file with Text Edit app if you need to copy/paste data from it.
