How do I Export a Layer State
camille_bobeau
camille_bobeau
I have Autocad 2024 on mac, and despite what some posts and videos I saw, the command LA or LAS do not give me any export options. I saved the list, but I can't seem to copy or export it. I don't understand how or why I don't get the same options as those people who also are on mac. Earlier version ?
My goal is merely to copy paste it in a text box, and there are A LOT of layers there so having to manually write them all will probably ruin my day.
Any genius help very welcome!
maxim_k
Hi @camille_bobeau ,
You can use -LAYER command to export layer state to .LAS file.
Here are the command options you use (I assume that you need to export "test" layer state):
Command: -LA -LAYER
Current layer: "Defpoints"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: A
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: EX
Enter name of layer state to export or [?]: test
Export state to file name <test>: ~    <- tilde gives you an option to open "Save as" dialog
Now you can import saved layer state to any drawing with the same -LAYER command:
Command: -LA
-LAYER
Current layer: "0"
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: I
Enter file name to import <Drawing1>: <- tilde gives you an option to open "Open file" dialog
Restore could not restore all line types.
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: R
Enter name of layer state to restore or [?]: test
You can also open .LAS file with Text Edit app if you need to copy/paste data from it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
camille_bobeau
Hi Maxim,
When I put in the command LA or LAYER it does not make appear any of those options you mentionned (see pic below)
I did save the list, however when I open the Layer state manager I do not have any export options (right click on the list does nothing)
I tried to simply copy paste the selected list in a text box or excel and no luck.
maxim_k
@camille_bobeau ,
You need to use -LAYER command (with dash in front of the command name):
I gave a link to the command in the help for a reason.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
camille_bobeau
OK I feel really stupid now. I hadn't realised the "-" was part of the command.
Thank you very much.
