Unsupported Objects
Unsupported Objects
mrpieterdelport
Unsupported Objects
mrpieterdelport
Unsupported objects window opens when I open dwg file on my Mac that were transferred from windows. I had to change from a windows laptop to a Mac computer. When I open the dwg file which was transferred from windows to Mac, the Unsupported Objects window opens. Please provide a solution so that I can open the dwg files on my Mac.
Keshava_Murthy
Hi @mrpieterdelport, thanks for your question.
I assume you were using AutoCAD Mechanical in Windows to create/open your drawings and now in your Mac, you might be opening them in AutoCAD.
Please help to read through this article and see if this address the issue you are facing.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-for-MAC-Ol...
"The drawing contains specialized objects which are not supported in AutoCAD for Mac.
Note: Such objects include those created in AutoCAD Toolsets (for example Mechanical, Architecture, or Map 3D) or in another Autodesk application such as, Civil 3D or Plant 3D. Mac versions of those products and object enablers are currently not available."
Please click ACCEPT SOLUTION if my post helps in solving your issue or answering your question.
Keshava Murthy
AutoCAD Mechanical Team
