I have an issue that is driving me batsh**
I have a truetype font that will not display in my drawings. Now I know this has been discussed here before, and after five days of research, both here and on the web in general, I cannot resolve it. FYI, I'm using AutoCAD LT 2017.
The font is in the system OS, and every other app on my Mac can display and print it ok. But when I try opening an existing drawing that uses this font, or creating a new drawing, setting up a new text style using the font, it displays an alternate font, like its not present on my system. Also, when I try to add a text box and choose the text style that uses the font, everything looks good until I type the first letter, then it switches the font type to "Arial".
I have attached 3 screen shots.
Image Screen1 is showing the correct "Text Style" and the correct TrueType Font selected.
Image Screen2 shows that when I type a capital "A" or any other character for that matter, the font changes to "Arial".
Image Screen3 shows the Text Style that has been setup.
This font has worked just fine in the AutoCAD windows world. I have recently switched to a Mac at work and cannot get the font to work on the Mac. I have tried adding it to the AutoCAD resources folder, deleting and reinstalling the Font, even deleting and reinstalling AutoCAD (AutoCAD LT 2017) itself, and several other tips I have found during my research that I can't even remember now, my head is spinning so hard now!
Help!
Mike
Solved by greenwoodmike. Go to Solution.
Solved by maxim_k. Go to Solution.
Well that's a small step in the right direction. Now I'm getting a "Square" Symbol instead of the Capital "A"
This is so frustrating!
Maxim, can you try the font again on your system and see what you get?
I feel really bad taking up your time on this, because its really not an AutoCAD issue, But you are the only one who has been able to rectify it in the past.
Thanks you so much for the time you have put in on this!
No Luck. Went through all my files on my Mac, and deleted every version of the font. uninstalled it from Font Book, rebooted, verified, that I was installing the file you sent, reinstalled, and now getting a square box.
Well, I think we have reached a resolution, at least kinda!
While I'm still only getting a square box when I use/view the font on screen, when I go to print or save to .pdf the font display and points properly. Kinda weird, but expectable.
Maxim, thank you again for all the time and effort you put in to helping me get this resolved.
Take care,
Mike
Sorry for the delay, I didn't see your response.
I'm running AutoCAD LT 2021.1 for Mac R.47.M.87
MacOS Catalina 10.15.7
