File Won't Open
File Won't Open
Message 1 of 33
File Won't Open
I was working on an AutoCAD drawing, finished, saved and closed out of the file. When I went to XREF it into a nother document, I noticed it would not work. I tried then to open it normally (both in AutoCAD itself and via my computer's hard drive) each time something flashes as if the file is about to open, but nothing appears. I am using the MAC version, and the preview shows up in my Finder, so it must be there but I can't access it at all. I've shut down AutoCAD completely but still no luck.
Any ideas? I'm using the  2013 student version for MACs and I attached the file if its helpful at all.
Thanks so much in advance,
Adena
Replies (32)
Message 2 of 33
maxim_k
Hi Adena,
Have you tried to start AutoCAD, type RECOVER command at Command window, and select your file in Open file dialog? With this command you can try to repair damaged drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 33
Thank you for the quick reply, Maxim - much appreciated!
Unfortunately, this did not work. Feel free to take a look at my screenshot below, but it doesnt have any information...
Message 4 of 33
maxim_k
Hi Adena,
I managed to recover your file in Windows version of AutoCAD, see attached DWG.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 33
Maxim -
Thank you so much for your help!
I'm so appreciative for your time. Any idea what it could have been or how I can attempt to avoid this in the future?
Many thanks again,
Adena
Message 6 of 33
maxim_k
Hi Adena,
It is very difficult to predict such cases (file corruption). Furthermore the inability to recover this file looks more like a bug (defect) in AC 2013 for Mac.
Anyway, you should know the exact location of .BAK files and how to open them in AutoCAD.
I think also you can always ask for help here on the Forum.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 33
I am having the exact same problem as the person above. I've tried the recover command and that isn't working. I will attach the file.
Message 8 of 33
maxim_k
Welcome to the Autodesk Forums!
I was able to recover in AutoCAD 2014.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 33
Sorry for asking the same over again but I am also having the exact same problem as the person above. I've tried the recover command and that isn't working. I will attach the file.
Message 10 of 33
maxim_k
Sorry, but I can not recover it too. (tried in AC 2014 and 2015 for Win)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 33
Thanks Nikki
Message 12 of 33
maxim_k
Hi Nikki,
Find your recovered file in the attachment.
I managed to recover it with RECOVER command in AutoCAD 2016.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 33
CamilaOV
Observer
Observer
Pleaseee! Help me recover this file. When I use the Recover command it appears to be empty but it ISNT! help!
Message 14 of 33
maxim_k
You can find your recovered file in the attachment.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 33
CamilaOV
Observer
Observer
Thank you SOOO MUCH!! Just saved my life!!
Message 16 of 33
Same here, please help me solving this
file attached
Message 17 of 33
pendean
Community Legend
Community Legend
Are you unable to use RECOVER command to open the file? Opens fine here with that command.
Message 18 of 33
i have solved it by opening the cad program and open the file i want inside it and this method already worked
Message 19 of 33
Im having the same problem with one of my files ... i have received the file on my email ... but cant fully open the file ... not all the layers are opened ... any idea why?
Message 20 of 33
maxim_k
Hi Ismajl,
Why do you think that not all layers are opened in the file?
Maybe they are frozen or turned off?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
