Extrim Comand on AutoCad for Mac
Message 1 of 12
I would like to know if the Extrim Comand does exist on AutoCAD for Mac.
Can anyone help me?
Cheers!
Elisa Puccinelli
Replies (11)
Message 2 of 12
maxim_k
Welcome to Autodesk Forums!
Hi Elisabeth,
No, EXTRIM command is not available in AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 12
Doesn't Extrim command exist even in AutoCAD 2016?
Message 4 of 12
maxim_k
It doesn't exists in 2016 version too.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 12
amandahgmartins
Is there any other solution for mac?
Message 6 of 12
pendean
Community Legend
Community Legend
There is a LISP out there called COOKIECUTTER, find it and give it a try, see if it works: there are multiple versions too I believe.
After that... you probably have to fake it with wipeouts and solid hatches etc.
Message 7 of 12
maxim_k
Hi @amandahgmartins ,
Not sure that COOKIECUTTER will work on Mac, as it has ActiveX functions in its code.
But you can try EXTRIM.LSP from AutoCAD r.14 CADTOOLS (Bonus tools). I slightly modified it so that it works in AutoCAD for Mac.
Download attached archive with two LSP files - EXTRIM.LSP and AC_BONUS.LSP. Extract it to some the path to which is specified in "Support Files Search Path" on Application tab of AutoCAD for Mac Preferences.
Use APPLOAD command to load EXTRIM.LSP and try EXTRIM command.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 12
amandahgmartins
It worked!!!
Thank you so much Maxim. 😀
Message 9 of 12
Matteo_L
Community Visitor
Community Visitor
Hey, thanks for .lsp, it also worked 😃
However, i am having some troubles to use it in an other .lsp file. It says " Unknown command "EXXTRIM" (see PS) even if i am able to use it directly in autocad.
Do you have any idea how to fix that?
Have a nice day,
Matteo
Ps i used a simple code such as
(defun c:Test_extrim ()
(command "EXXTRIM")
(princ)
It is called EXXTRIM because i feared collusion with other annotations
Typing EXXTRIM in Autocad gives the good command .
Message 10 of 12
maxim_k
Hi @Matteo_L ,
Try to use (C:EXTRIM) instead of (command "EXTRIM").
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 12
Matteo_L
Community Visitor
Community Visitor
Thanks for the answer!
Is there a way to automate the boundary selection?
Tried this
(c:EXXTRIM)
(command boundary)
(command pt_outside)
with boundary and pt_outside being defined earlier but the prompt "Pick a POLYLINE, LINE, CIRCLE, ARC, ELLIPSE, IMAGE or TEXT for cutting edge" keep poping up.
Sorry if the questions are a bit dummy, trying my best! 😃
Message 12 of 12
maxim_k
Hi @Matteo_L ,
Probably possible - you need to rewrite some of the code in EXTRIM.LSP
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
