AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Exporting to obj or fbx
10 REPLIES 10
Message 1 of 11
5966 Views, 10 Replies
I'm using autocad for mac for my drafting and sometimes for 3d
I also work on blender (where I mostly do 3d)
Thing is blender cannot open dwg or dxf but it can open stl,obj,fbx,dae and a few more
How can I bridge between these two?
I tried fbx converter and got empty files every time...
10 REPLIES 10
Message 2 of 11
maxim_k
Welcome to the Autodesk Forums!
Have you tried STLOUT command in AC for Mac.
It creates STL files from solids or watertight meshes (even if they are inside blocks and in Xrefs) in your drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 11
in reply to: maxim_k
It works for 3D objects which is great! It's a good beginnings!!
But how can I get 2D drafting out of autocad to another format?
Thank you!
Message 4 of 11
maxim_k
DXF ?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 11
dxf is not supported on blender...
maybe there's a way for exporting svg?
Message 6 of 11
maxim_k
Message 7 of 11
the dxf plugin is old and not stable it's not something you can use on daily work
I tried importing in every possible plugin but non of them is stable or working properly(the best result i got was importing an arc) this is why i'm searching for better export options...
Message 8 of 11
maxim_k
Don't know really which 2D format Blender can import, but look at Rhino for Mac:
http://www.rhino3d.com/mac
it has a lot of file formats to export:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 11
i found this wonderfull website:
http://www.greentoken.de/onlineconv/
it's fast easy and it works!!
thank you for all your help 🙂
Message 10 of 11
maxim_k
Thanks for sharing your findings!
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 11
DrGraebener
bull****, you have to activate this in the preferences, then it's available
but it doesn't work properly
