Welcome to the Autodesk Forums!
Have you tried STLOUT command in AC for Mac.
It creates STL files from solids or watertight meshes (even if they are inside blocks and in Xrefs) in your drawing.
Maxim
the dxf plugin is old and not stable it's not something you can use on daily work
I tried importing in every possible plugin but non of them is stable or working properly(the best result i got was importing an arc) this is why i'm searching for better export options...
Don't know really which 2D format Blender can import, but look at Rhino for Mac:
it has a lot of file formats to export:
Maxim
i found this wonderfull website:
http://www.greentoken.de/onlineconv/
it's fast easy and it works!!
thank you for all your help 🙂
