AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Dynamic input question
3 REPLIES 3
neillyditt
278 Views, 3 Replies
I'm having an issue with dynamic input and stretch grip.
As an example if I want to draw a rectangle and I get my x dimension from something already drawn  - a wall thickness for example  - I hover the cursor over the x dimension and the 'grip' happens which locks me onto that x dim - if I then want to input the y coordinate I press the tab key to change the input from x to y but by doing that I lose the grip lock on the x dim - its really frustrating.  In previous versions I have been able to hover on the x coordinate and lock it in then just input the y coordinate without even pressing the tab key  - it was so brilliant.  But  now I can't figure out what I need to do to get this back in 2023 LT for Mac.
Any help greatly appreciated
Any
3 REPLIES 3
maxim_k
in reply to: neillyditt
Hi @neillyditt ,
Do you use Object Snap tracking?
Can you illustrate somehow what happens?
Maybe screen recording?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
neillyditt
in reply to: maxim_k
Hi.
I have attached a quick video - Very quick to keep the file size down - hopefully this demonstrates my issue
maxim_k
I checked in 2023 version and the behavior is the same.
If you want to use Object snap tracking for Y coordinate, you have to switch off Osnap before you hit TAB key:
1/ Enable Object snap tracking
2/ Start RECTANG command and pick the first corner using Object Snap
3/ Hover over the second reference point to start tracking, move mouse in the direction you want to pick the second corner
4/ Turn off OSNAP (F3 or Fn+F3)
5/ Use TAB key to switch to the other side dimension (Y coordinate), type the Y value
6/ Hit Return to complete RECTANG command
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
