04-05-2023
05:00 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-05-2023
05:00 AM
I checked in 2023 version and the behavior is the same.
If you want to use Object snap tracking for Y coordinate, you have to switch off Osnap before you hit TAB key:
1/ Enable Object snap tracking
2/ Start RECTANG command and pick the first corner using Object Snap
3/ Hover over the second reference point to start tracking, move mouse in the direction you want to pick the second corner
4/ Turn off OSNAP (F3 or Fn+F3)
5/ Use TAB key to switch to the other side dimension (Y coordinate), type the Y value
6/ Hit Return to complete RECTANG command
Maxim Kanaev
Architect
MARSS
