AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Dynamic Blocks with 3D Objects
6 REPLIES 6
4011 Views, 6 Replies
I would like to know if it's possible to create parameters and actions in Block Editor with 3D Objects. I tried today for the first time without any success. When trying to select the points for a linear parameter, for example, AutoCad tells me: "Invalid 2D point". Is there anything I can do?
Thank you in advance.
6 REPLIES 6
maxim_k
Hi Josefina,
Although geometry in dynamic blocks can be 3D, but AutoCAD allows to create only 2D parameters and actions.
Please check that Z coordinate of the points you select for linear parameter equal to zero.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Hello Maxim,
Ok thank you, I'll try with your advice.
Emmsleys
Hello @Anonymous,
You can assign parameters to an existing 3D block definition, but you cannot edit the block along the Z axis.
Please see this AKN article for information:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-LT-MAC/files/GUID-B6BF48AD-9408-4BE8-992D-4B7823F790F5-htm.html
Sarah Emmsley
Technical Support Specialist
in reply to: Emmsleys
Thank you!
Emmsleys
 @Anonymous,
Happy I could help. 🙂
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
You can either use 3F Faces or 3D Surfaces.
3F can be easily stretched.
For 3D Surfaces created by Sweep, you must keep the path. Include the path in the selection of the stretch action but DO NOT include the 3D Surface itself. Once the path is stretched, the 3D surface will follow.
Also when asked to select points, you can use ".xy"... pick then specify z as 0
