Drawing a Hexagon
Drawing a Hexagon
Message 1 of 9
Drawing a Hexagon
Dear members,
I like to draw a Hexagon in AutoDesk with all sides having the same messurements.
The hexagon must be like a pipe with a hole from beginning to the end.
Any help I appreciate ...
Thank you.
Dimaxum
Replies (8)
Message 2 of 9
maxim_k
Welcome to Autodesk Forums!
Hi Dimaxum,
If you want a tube in a shape of hexagon, you can try to use SWEEP command to sweep two circles on a hexagon path, than subtract the tube with smaller diameter from the tube with bigger diameter.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
Hello Body,
Thanks for the welcome ...
Isn't that a little to complex for just a hexagon?
I need more than just 1 hexagon, I like to fil a circel with them.
Like a pipe with filling up, attached with hexagons. Like a honeycomb.
It is that I just started to using AutoCad and honestly it's not easy to use.
I have already draw the design in Adobe Illustrator and it looks just fine, but I can't use this for 3D printing.
Dimaxum
Message 4 of 9
maxim_k
It is even easier - see attached DWG.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
Hi Body,
YES, this is OKAY ... but how did you do it?
I was struggeling by just trying to make only 1.
Did you design it in AutoCad or Illustrator and save it as DWG?
Dimaxum
Message 6 of 9
maxim_k
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
Hello Body,
Thank you for the video ... clear to understand, an easy to draw.
But how stupid a men can be I proved today.
I am NOT working in AutoCad, but in "AutoDesk Invernter Fusion" and tha's a differen pair of shoes.
Dimaxum
Message 8 of 9
Dear Body,
Thanks again for the clear explanation by drawing a Hexagon-Pipe.
I downloaded today AutoCad for Mac and starting to look some teching videos.
very interesting, but it will take while to draw the obeject I like to have.
Dimaxum
Message 9 of 9
JDMather
Attach your image here
http://forums.autodesk.com/t5/inventor-general-discussion/hexagonal-in-a-tube/m-p/6261375#M588674
