AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Дополнение или LISP для случайных чисел
1 REPLY 1
mars_faiziev
157 Views, 1 Reply
Hello. I need LISP or an additional program for AutoCAD for Mac that will replace Mtext values ​​with random values ​​in the interval I need. For example, I have 200 identical numbers indicating millimeters in Mtext format, and I need these numbers to change from -10 millimeters to +10 millimeters or 1 to 10 millimeters in random order. I am a surveyor and fill out executive plans a lot. Before that, I used AutoCAD for Windows and there was such an option, but it is in the VLX format, which is not available for AutoCAD for Mac. Please, if you know the solution to this problem, tell me how to do it. Thank you very much
[ The post content has been copied out of the "code window" for clarity by @pendean Original]
1 REPLY 1
maxim_k
in reply to: mars_faiziev
Hi @mars_faiziev ,
It is better to ask your question here:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Don't forget to mention that you need it for autoCAD for Mac and must be written in "plain" AutoLISP, without using Visual LISP.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Technology Administrators
