By accident I constantly activate 3D orbit by pressing Shift+Middle Button.
Is there any way to turn that shortcut off? It is driving me nuts!
Best, Jens
Hi @jvsk_V9TUMDGBR3BE ,
I'm afraid - it is impossible on Mac.
But you can try "workaround" - set System Variable MBUTTONPAN=0, then you will see OSNAP context menu instead of 3DORBIT. You also won't be able to pan using the middle mouse button.
Thanks for your answer, well maybe it could work, but I would need to fix a new hot-key for panning then-but maybe that just might be the workaround I need.
@jvsk_V9TUMDGBR3BE wrote:...but I would need to fix a new hot-key for panning then....
Use Spacebar panning - press Spacebar an then pan with mouse as usual. This works inside commands.
As for me - I prefer to use mouse wheel zoom out/in instead of pan.
