11:58 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I usually dimension in layout space, when i need to make a change on the drawing sometimes i need to move the object or zoom in or out, of course the dimensions are not griping where they're supposed to now. some time a go I saw a tutorial were you can fix this with one command, you just punch it in and the dimension grips moved to the point it was dimensioning even if you zoomed in and out or moved around in the viewport, can't remember what that command was, does anybody know what that could be?
