dimensions moving in layout
No aplicable
I usually dimension in layout space, when i need to make a change on the drawing sometimes i need to move the object or zoom in or out, of course the dimensions are not griping where they're supposed to now. some time a go I saw a tutorial were you can fix this with one command, you just punch it in and the dimension grips moved to the point it was dimensioning even if you zoomed in and out or moved around in the viewport, can't remember what that command was, does anybody know what that could be?
0 Me gusta
Responder
Soluciones aceptadas (1)
2.960 Vistas
5 Respuestas
Respuestas (5)
pendean
Community Legend
Community Legend
>>>...I usually dimension in layout space...<<<
If you move things around often, it appears you probably need to start changing your workflow processes to compensate, and dimension/annotate inside the viewport instead. It's the primary reason why annotative text/dims/blocks were created 10+years ago in AutoCAD.
I believe you seek DIMREASSOCIATE command.
No aplicable
don't think that command does what im looking for, but ill look into the annotative dimensioning, thanks.
0 Me gusta
Victoria.Studley
Solución aceptada
Hi @Anonymous,
Welcome to the Autodesk Community and thank you for posting your question here in the AutoCAD for Mac forum!
In addition to @pendean's recommendation to try the DIMREASSOCIATE command, you might want to try the DIMREGEN command.
This will realign the dimensions with your geometry if you pan or scale the viewport. If DIMREGEN doesn't work on some dimensions, you might then need to use DIMREASSOCIATE. I tested the DIMREGEN command in AutoCAD for Mac just now, and confirmed it works there. Could you try it out?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
No aplicable
Yes, thats going to be the one DIMREGEN, thank you.
0 Me gusta
No aplicable
this is not working what you said i have 20 layout in 1 sheet when i am changing any drawing in model or layout it is all dimension are moving please sent me good solution in registered email
0 Me gusta
