Degree direction messed up
No matter what command or option I set, Autocad LT will always set 90 degrees south and 270 degrees north. It always revolves clockwise and it's driving me draving my crazy.
I've tried angdir command set to 0, no good
In the Units tab the angle direction is not set to clockwise but still is clockwise.
maxim_k
Welcome to Autodesk Forums!
Does this happens in all drawings? Or just in one?
Have you tried to restart AutoCAD (quit it with QUIT command and launch again)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Yes, it happens with all drawings. I've tried un-installing and re-installing.
maxim_k
What about reset? Have you tried to reset AutoCAD options from the Application tab of the AutoCAD preferences?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Yes behavior is the same after a prefrence reset
maxim_k
Are you sure you are using correct UCS in your drawings?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
