I am having great difficulty working out how to customise keys. I cant find the option in the CUI...
help? or am I not seeing somethign obvious?
Just as with most everything else in this release, it is very limited in it's capabilities. If you have found the Customize > Interface(CUI) in the Menu Bar, you've seen that there are limited modifications that can be made.
Autodesk seems to be proud that they created the Mac version without porting, but if porting portions of the PC version would have made the application work better, I would have preferred it.
I have also alot of trouble with customizing the menu's/shortkeys etc.
What i am trying to do is to change cmd-c ( copy) to (copy with base line) wich is now set to ctrl-shift-c
In the windows version i used this worked like a charm but i cant find out if it is possible in the mac 11 version.
I can change the copy button tot copy with basepoint, i can change the names in the edit>copy menu
but i CANT change the ctrl-shift-c behind the name into cmd-c...
Is it possible ?
Thanks in advance!
