Custom Hatch unable read
steviewo76
steviewo76
Can somebody please tell me if I need to do something with downloaded/custom hatch .pat files (i.e. is it something to do with the file format or wording in the pattern file)??
I have several patterns that worked for me for years on Windows version and also some new ones I'm trying to use. I have them installed in a a separate folder and am able to pick them in the hatch dialogue box, but when I go to actually press OK to apply them, they won't preview or apply and I get the message "Alert Error in reading the pattern file".
It's driving me mad - I'm trying to finish a produject and have got a huge headache!!
maxim_k
Hi @steviewo76 ,
I now that some hatch patterns, especially complex, that are usable in Windows version of AutoCAD don't work on Mac.
Can you share one of the problem PAT files here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
steviewo76
Hi - I've actually found one that works, but its really slowing down my machine.
However, here are. couple that won't work - one is complex and one is relatively simpler.
hugha
PAT files are simple text files. Add a blank line to the end of both files and eliminate the blank line following *OSAGE in the larger.
AutoCAD is unforgiving of files that do not follow quite unnecessarily stringent formatting requirements.
hth,
Hugh Adamson,
www.hatchkit.com.au
steviewo76
Thanks @hugha - but still doesn't seem to work for me.
Do you use the TextEDit programme on Mac for .pat files? By default it tries to use MS Word.
maxim_k
Hi @steviewo76 ,
Both hatch patterns works on my Mac (AutoCAD 2023 for Mac), if I use ACADISO.DWT template to create new drawing, then I get this result:
Indeed, OSAGE.PAT slowing down AutoCAD for Mac and you cannot do nothing about it. You need to look for a similar, but less complex hatch pattern.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
steviewo76
Very strange - now appears to be working. So - I started a new blank drawing and applied them, then copied and pasted from the new drawing into the previous drawing I had been trying them in and they worked.
