I have restarted multiple times. others indicate a hardware acceleration issue but i do not find that setting. any other ideas?
I did just did a reset application options in Autocad, same issue. started recently and i though maybe due to installing MagicPrefs which I did to help with horizontal scrolling randomly. MagicPrefs solved that issue. But since this started thought it was the culprit so I uninstalled MagicPrefs and it is still happening. I can reinstall Autocad next if you think that is best.
i'm pretty sure, i have searched thoroughly to make sure no files are left. can you please provide me with instructions on how to uninstall and then reinstall AuotCad Lt 2014?
have sierra on my macbook, but it's been working fine since i installed it, only started misbehaving recently. and i use AutoCad Lt 2014 if that makes a difference...do i need to change the AutoCad version I am using? can't change macOS
does that mean i have to buy the more recent version - not sure that's an option if there is a fee? do i do that thru technical support?
Did not have any knowledge of this issue before updating my MacOS. I cannot downgrade to older operating system, that is not an option. Will new versions of AutoCad work with Sierra?
does that mean 2014 will never have an update to fix compatibility? i'm pretty much stuck with the issues unless i upgrade auto cad? totally uncool.
Following up on your thread.
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
