Command z on Mac with AutoCAD 2024 doesn't work
julie_vangansbeke
Message 1 of 9
julie_vangansbeke
I recently bought an MacBook Pro and I'm trying to figure out wat the "undo" command is for autocad 2024. On my previous pc it was "ctrl+z" and after looking online it seems to be the same for apple but with command instead of control. The problem is, it is not working for me. When I do command+z they ask me if I want to close my file... I really don't know how to solve this and working on autocad without the "undo" function is a real hell. Please help! Thanks in advance.Foto 2-05-2023 om 22.43.jpg
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
What happens if you just type UNDO to execute it?
How about the abbreviation U?
And to be clear, this is what you are doing but only getting the CLOSE command activated, yes?
Message 3 of 9
maxim_k
Hi @julie_vangansbeke ,
It looks like you have a similar problem as in this discussion:
https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-lt-for-mac-cmd-z-undo-bug/td-p/11907113
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 9
julie_vangansbeke
UNDO does work but it is not as efficient and the abbreviation U doesn't work neither, is something wrong with my settings? And yes indeed, when I try 'Command+Z', the CLOSE command gets activated.
Message 5 of 9
maxim_k
Start CUI command, scotch to Shortcuts tab.
Do you see the same as in the screenshot or something else?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 9
thelma_lefevre
Community Visitor
Community Visitor
Hello, I have the same problem! I use an azerty keyboard and this is what I have in the CUI for the undo ( annuler in fench ) command. Have you found a solution to restore ctrl+z ?
Message 7 of 9
maxim_k
Hi @thelma_lefevre ,
You don't need to use workarounds, but you need to install >>>>THIS<<<< Update instead.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 9
hassandesigns509
Observer
Observer
To resolve the issue with the "Undo" command in AutoCAD 2024 on your MacBook Pro:
Confirm that "Command + Z" is set as the "Undo" shortcut in AutoCAD's Keyboard Shortcuts.
If the shortcut seems correct, reset AutoCAD's keyboard shortcuts to default settings.
Check macOS System Preferences to ensure there are no conflicting keyboard shortcuts interfering with "Command + Z."
These steps should help you regain the "Undo" functionality in AutoCAD on your MacBook Pro.
Message 9 of 9
thelma_lefevre
Community Visitor
Community Visitor
It works ! Thanks a lot !
In shortcut I set " ctrl+Z" for undo ( because I can't set "command+Z") but now to undo I have to tap " ctrl+z", weird but it works !
