Have to enter any & all commands in the command bar. Cursor cannot be anywhere else on screen?? ?
The topic title has been edited to improve findability by @alina.balkanskaia.
Solved by jessica.kaushik. Go to Solution.
If not sure I understand the question but maybe you are looking for the dynamic input? Use F12 key to turn on and off
Do you mean that you can't see the mouse pointer or crosshair? If that's the case, you might need to turn off the hardware acceleration.
Cheers,
Edwin Prakoso
Reset AutoCAD/LT like this https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
HTH
@jessica.kaushik Hello; nice to see you on Forum! Glad to see that this discussion helped you to find the answer. Thank you for marking the Solution cos it helps to find the topic in searching systems and could save users time in the future.
