Columns and rows in tables are too big
ruirego
Message 1 of 12
ruirego
How can I reduce the column and row in the table?
(note: when I inserted the table, it was too big I had to reduce the size of the latter 10 X)
Replies (11)
Message 2 of 12
maxim_k
Hi @ruirego ,
Select cell inside table and change its width and height in the Properties palette:
Or use these grips to adjust width and height manually - select grip and drag it to the new position:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 12
ruirego
hello Maxim,
its not the cell, its the top cell (the grid).
i think it has something to do with scale?! because i tried to insert a cell in a new  file without scaling down and it was fine.
r^2
Message 4 of 12
maxim_k
@ruirego ,
I think this information from AutoCAD online Help should help you:
Customize Display of Column Letters and Row Numbers
By default, the In-Place Text Editor displays column letters and row numbers when a table cell is selected for editing. Use the TABLEINDICATOR system variable to turn this display on and off.
 The text color, size, and style and the line color are controlled by the settings for column heads in the current table style.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 12
maxim_k
What AutoCAD for Mac version do you have?
Do you insert table from another drawing?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 12
ruirego
thanks Maxim!
it normal now.
something to do with the "In-Place Text Editor"... not sure what is that nor how to define default sizes.
r^2
Message 7 of 12
ruirego
i have Autocad LT for Mac
i didn't insert from other drawing. but i tried to paste this table in a new drawing with a different template and it was normal!?
r^2
Message 8 of 12
maxim_k
Hi @ruirego ,
The size of column heads is defined in table style.
If you have 2023 version of AutoCAD LT for Mac, you can edit Table Style with TABLESTYLE command. If you have an earlier version of AutoCAD LT, you cannot do this on Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 12
ruirego
hello maxim,
TABLESTYLE doesn't have a field do change this
r^2
Message 10 of 12
maxim_k
Hi @ruirego ,
Please look at this:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 12
ruirego
hello maxim,
not the header size. the row's and column size. please check my image
Message 12 of 12
maxim_k
Hi @ruirego ,
The size of cells of column letters and row numbers depends on text size of the title, header and data cells. Plus there is relationship between text height in title, header and data cells and settings of MEASUREMENT and INSUNITS System Variables.
If you have the drawing with MEASUREMENT=1 and INSUNITS=4 (typically the drawing created with metric acadiso.dwt template) and the size of text for the cells in current Table Style is too small - for example: 0.125 units - the table will look like this:
If you set text size for the cells to 4 in the Table style in the same drawing and create new table, the table will look like this:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
