Drawing Appears Differently In Viewport vs In Model Space
ashley.kassis
Message 1 of 9
ashley.kassis
Sometimes this will randomly happen and I have no idea why. This is not the usual line type scale factor issue between model space and paper space. My lines are appearing totally different in my drawing (model space) vs my sheet (paper space). They go from being straight to diagonal, I have screenshots to show what I'm talking about. It'll only happen where some of the lines appear different, it's not all of them. I tried REGEN and REGENALL and nothing's changed. Screen Shot 2022-11-06 at 1.24.56 PM.pngScreen Shot 2022-11-06 at 1.25.06 PM.png
Replies (8)
Message 2 of 9
ashley.kassis
Screen Shot 2022-11-06 at 1.24.56 PM.pngScreen Shot 2022-11-06 at 1.25.06 PM.pngSometimes this will randomly happen and I have no idea why. This is not the usual line type scale factor issue between model space and paper space. My lines are appearing totally different in my drawing (model space) vs my sheet (paper space). They go from being straight to diagonal, I have screenshots to show what I'm talking about. It'll only happen where some of the lines appear different, it's not all of them. I tried REGEN and REGENALL and nothing's changed.
Message 3 of 9
maxim_k
HI @ashley.kassis ,
Can you share your drawing or part of it here on the Forum?
This could help to answer your question.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 9
ashley.kassis
Unfortunately, I just ended up redrawing the lines and it fixed them from being diagonal back to horizontal. I would still like to know if anyone else has had experience with this same issue.
Message 5 of 9
maxim_k
Hard to say without having your drawing at hand, but maybe there is a problem related to the 3D position of the endpoints of the lines in your drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 9
imadHabash
Are you using AutoCAD for Mac ?
Imad Habash
Message 7 of 9
ashley.kassis
Yes this is AutoCad for Mac.
Message 8 of 9
vinodkl
Hi @ashley.kassis
From the snapshot shared I could see that the crosshair color is changed to red and green and the crosshair is not exactly straight, which means the UCS is slightly rotated. UCS gets slightly rotated unknowingly sometimes while "Panning" holding the scroll button and pressing the shift key. To fix this type in the command(in modelspace) "PLAN" and then select "World" from command line or type in the "W" and enter. Hope that fixes your problem 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 9 of 9
ashley.kassis
Thank you so much for pointing that out!
