- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to change the double-click action on blocks to the simple attribute editor (ATTEDIT) rather than the so-called enhanced attribute editor (EATTEDIT) - which is actually much slower to use if you only want to fill in or change attribute values.
I found an earlier post 5422445#M13595 on the subject so it seems it is possible, but its not clear how to do it. Could someone (Maxim
) could give a step by step instruction on how to do this? I have found menugroup.cui but no idea where doubleclickroot.cui resides, both are referenced in the post.
