AutoSave problems
AutoSave problems
neillyditt
Message 1 of 9
AutoSave problems
neillyditt
Hello.
I have a problem with Autosave since updating to AutoCAD LT 2017.  I've never had a problem with retrieving Autosaved back up files.
In Preferences Application The Automatic Save file location is users/*myname*/documents/ Autodesk/Autosave.  When I try and find this file it doesn't exist.
As i say, this has never been problem before and Autocad LT has been crashing a lot recently and I am losing crucial work because of this issue.
Please help!
Neil
Replies (8)
Message 2 of 9
maxim_k
Hi Neil,
Autosave works fine on my system.
users/*myname*/documents/ Autodesk/Autosave is not a file, but the path to the folder with name "Autosave".
If you don't have such folder on your Mac, try to create it, than AutoCAD will be able to use it as autosave folder.
Alternately you can create special folder inside your Home folder for AutoCAD autosave and change the default path for Autosave folder in AutoCAD preferences to this newly created folder.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
Emmsleys
I don't have an issue on my end. I've come across another thread where the user created a LISP to run every time AutoCAD would open to ensure that his files were being saved.
Let me see if I can find that thread or an article to help.
Did @ maxim_k post help answer your question?
Is this happening with all your projects?
Sarah Emmsley
Technical Support Specialist
Message 4 of 9
Emmsleys
neillyditt,
Please feel free to post back if you still run into an issue with other files or you need additional support on troubleshooting this issue.
Thanks.
Sarah Emmsley
Message 5 of 9
Emmsleys
Hello @neillyditt
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
Message 6 of 9
kristinabhalter
I also have this problem. Autocad 2017 Mac will not autosave. I have reset and tried the savetime command and it still will not autosave, no matter which folder I choose.
Message 7 of 9
maxim_k
Hi Kristin,
Which macOS do you have on your Mac.
I have no problems with Autosave in on High Sierra.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 9
wei503
Hi @kristinabhalter,
How do you check the autosave function? Please note the following tips:
- autosave will not be triggered until the savetime is up.
- the savetime is in minutes.
- default save path is under ~/Documents/Autodesk/Autosave/
- when savetime is up, autosave on Mac will not be triggered if autocad is keeping in a model dialog, or if no user action at all. Just run any command or select anything in canvas will trigger the autosave on Mac.
- also important to know that the existing autosaved files for a drawing will be removed once you save the drawing manually, for example, run qsave.
Wei Ma
AutoCAD QA Manager
Message 9 of 9
maxim_k
Hi Wei,
>>>> if autocad is keeping in a model dialog...
Did you mean "modal dialog"?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
