AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AUTOMATIC COPIES NUMBERED
2 REPLIES 2
ptplans
383 Views, 2 Replies
HEY Autocad for Mac forum:
I wanted to know first, what is happening when my drawing is automatically copied in number sequence?
Is there any way to turn that off?
See attached photo showing automatic list generated.
2 REPLIES 2
maxim_k
in reply to: ptplans
Hi Paul,
That is because the drawing you edit is inside folder with iCloud sync enabled.
This problem exists in AC for Mac since Apple introduced iCloud drive sync on macOS, there are two workarounds:
- don't store drawings you want to edit in iCloud enabled folder
- turn off creation of BAK files by setting system variable ISAVEBAK=0 (https://help.autodesk.com/view/ACDMAC/2020/ENU/index.html?guid=GUID-25AF36C1-CA4A-4C1C-8D93-1C4F436C...)
Here is AKN article about this problem:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Files-do-not-overwrite-w...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ptplans
in reply to: maxim_k
Hey Maxim,
Thanks for always being so quick and thorough.
Really appreciate.
...  Paul Wood
