Automatic block attributes value.
arnasvel
Message 1 of 14
arnasvel
Hello again,
I have an issue. I have a tree icon block and in attributes I need to change the value for "numeris".
It's supposed to be in order from 1 to whatever it is in dwg file.
Is there any possibility to do this automatically?
I putting on a screenshot for it to be more clear. The upper tree with red arrow supposed to be 1 (first). The second supposed to be 2 (second) and so on. So is there any possibility to change these exact values auto?
@arnasvel
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Automatic block attributes value.
Replies (13)
Message 2 of 14
maxim_k
Hi @arnasvel ,
Definitely - you need AutoLISP routine.
Do you have full AutoCAD version? Can you use AutoLISP?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 14
arnasvel
Yes I have full Autocad and AUTOLisp plugin.
Message 4 of 14
maxim_k
@arnasvel ,
Can you share drawing with at least one block you want auto-number inserted?
I prepared simple rough AutoLISP routine, but I need to know the exact TAG name of the attribute you need to populate automatically.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 14
arnasvel
Here You go.
It doesn't matter if it's conifer or decidous tree block. Value in "numeris" have to be from 1 to whatever it takes.
I hope I can understand how to do that.
Message 6 of 14
maxim_k
Hi @arnasvel ,
Please find AutoLISP file in the attachment.
You need to load it with APPLOAD command, then you can use new command - BL_NUMBER.
AutoCAD will ask you the number to start with, then it will ask to select objects.
You can select all objects (blocks) in the drawing and hit Return twice - in this case in all blocks that have attribute with tag "NUMERIS" these attributes will be populated with sequential numbering. The numbering will start from the  last inserted block and will end in the first inserted block.
You can select blocks one by one until you hit Return on the second prompt "Select objects", in this case the numbering will start with the first selected block and will end with the last selected block.
If this routine will help you, all kudos should go >>>>there<<<<
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 14
arnasvel
Thank You very much!!! Also getting kudos where You showed!
Message 8 of 14
arnasvel
So okay. You saw my drawing. Attribute value is in. Can I also somehow make that only value visible on drawing and not all. Cause it's easy to to Attdisp > on. But then it show a lot of things I don't need.  Or its depends how block are created?
Message 9 of 14
maxim_k
Hi Arnas,
You can make this attribute visible by editing block definition:
- Open tree block in Block Editor, select attribute and uncheck Invisible property in the Properties palette:
If you need, you can also adjust thee position of this attribute inside block.
- Save block, close Block Editor,
- Use ATTSYNC command to synchronise attribute definition change.
Now this attribute is visible in all block insertions.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 14
alina.balkanskaia
hHello, @arnasvel! Glad to see that you have found the solution here!
Always big thanks to @maxim_k, a fantastic specialist who finds time to share his knowledge!
Alina Balkanskaia
Message 11 of 14
limnakhau
Community Visitor
Community Visitor
I'm trying to scale a dynamic block based on the numeric value of an attribute.
I suspect one of these is the right approach:
  • How do we set a Property Lookup Table entry from an Attribute?
  • Or set a Block Properties Table item based on an Attribute?
  • Or set an Attribute value as a global variable https://omegle.onl/?
Specifically, I'd use the annotation scale, which can be easily assigned to an attribute by the CANNOSCALEVALUE system parameter.
Message 12 of 14
maxim_k
Hi @limnakhau ,
Can you provide more details about the way you want to scale dynamic block?
Do you want to scale it depending on the value of one of its attributes?
Keep in mind that Property Lookup Table and Block Properties Table are not available in AutoCD for Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 14
vincent.cussey
Observer
Observer
HI,
Many thanks for this post.
I Have a question ?
What do you modify in Autolisp if I want to change the value of incrementation ?
The value of incrementation is a answer of a question ?
Exemple :
I select many blocks.
I execute BL_NUMBER
And I had 2 questions :
Start Number ?  my answer "1"
Offset Number ? My answer "2"
My result is :
First 1
Second 3
three 5
etc...
Many Thanks at all
Vince `
Message 14 of 14
vincent.cussey
Observer
Observer
Hi
I found It
Sorry
