AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD on 13" Macbook pro has slow laggy curser, are my graphics to blame?
6 REPLIES 6
1088 Views, 6 Replies
Hello, I am a high school student in a technical school part time learning engineering and architectural design. I use the base 13" 2017 pro with a 256gb SSD but have pretty bad time as far as zooming in and out, moving around the drawing and curser lag. I've tried to fix this by setting different values to 0, turning off 3D object snap, and giving autoCAD full disk accses but it hasn't fixed any of my issues.
I am worried this may be an issue with maybe my computers graphics as all I have are integrated graphics Intel Iris Plus Graphics 640 1536 MB. But at the same time, I can play Minecraft just fine which is far demanding than my drawings. Also on this forums I have seen others using a 13" pro with the same graphics having no issues.
6 REPLIES 6
maxim_k
Welcome to Autodesk Forums!
Hi Lucas,
What AutoCAD version are you using?
Do you have this problem in all of your drawings, even in empty, newly created?
Do you create and edit 2D drawings? Or they have 3D objects?
What about current Visual Style? Is it 2D Wireframe or different one?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Thanks for the response,
  • I'm using Q.46.M.205, when I check for updates it says I'm on the latest version.
  • Yes I have this problem in all drawings, different default templates and blank ones.
  • I only do 2D drawings I don't use 3D
  • My visual style is 2D Wireframe.
maxim_k
Have you tried all steps from this AKN article?
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Another attempt.
Is your Mac connected to the Internet?
Do you have File Sharing turned on your Mac (macOS System Preferences -> Sharing pane)?
If no, try to turn File sharing ON, you even don't need to select folders to share. Test AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thank you, turning on file sharing did have a dramatic impact, still not as smooth as I’d like but actually usable now.
arthuralaor
Hello Mate! I saw your post about AutoCAD running slow on your MacBook Pro 13" 2017.
I was struggling w the same problem and unfortunately the solution described by other user didn't help.
But today i found a way to "fix" this problem and run your drawings at a better frame rate. Autocad have a bar at right that show Layers, Properties and other information. Try to hide that bar. My MBP runs my drawings smoothly now. The only problem is the Layer window floating above the "model" space.
