Hi folks
I'm using ACAD LT for MAC and would like to batch publish sheets to PDF without the file name included
I have had a look around but can't see a setting or work around out there to solve this issue on this particular platform
Many thanks
Solved by maxim_k. Go to Solution.
Hi Ian,
If you uncheck "Single PDF with multiple sheets" option in Batch Publish window:
AutoCAD will not ask you for file names for PDFs included in Batch Publish. To be sure that PDFs will go to necessary location, you need to set it after you add Layouts to Batch Publish list.
Hi Maxim, thanks for the reply
I use the single PDF option, but what I am asking is there a way to automatically generate the PDF file name without the name of the cad file prepended to it with the hyphen
for example:-
cad file name “house”
sheet name “01 plan”
file generated is “house-01 plan”
i would like just “01 plan”
Hi Maxim
I thought as much, most annoying as I have literally hundreds of drawings to produce and the dochosting system the client uses won’t accept hyphens in inappropriate places 😞
Thanks anyway
Hi Maxim
You, sir, are an absolute star !!
I have just played around with it and it works flawlessly, now just have to learn how to refine it and incorporate into my flow
Thanks again
Hi Maxim,
I have also the same problem with my AutoCAD LT on MacBook. I don't understand your solution with project manager. Could you explain it for me pls?
Arnaud
Hi Arnaud,
@arnaudS4FEP wrote:Hi Maxim,
.... I don't understand your solution with project manager. Could you explain it for me pls?
Arnaud
You can add your drawings to new Project and then in Project Manager:
