AutoCAD LT 2016 MAC: HATCH: How to remove secondary Hatch pattern?
Darryl-CGA
Darryl-CGA
 I created this HATCH pattern a while back and can't figure out how to only remove the AR-SAND [White] hatch and leave the SOLID [Blue], let alone how I did this in the first place. I don't see a way to unselect it. If I choose SOLID, then it turns White and the Blue RGB is not in the drop-down menu. So the only way is to re-enter the RGB color for Hatch Color? And Background Color? Why am I not understanding this? Robot Mad
Darryl-CGA
Yes, that's how you do it; change Pattern: to SOLID. Hatch Color: Select Color and manually enter RGB from Background RGB and Background Color changes to None. I was over thinking it.
