AutoCAD issues on the new Macbook Pro with touchbar
wei503
Community Manager Community Manager
Message 1 of 20
wei503
========Update on 1/25=============
The 2017.0.1 hotfix is released. Click menu AutoCAD > check for Update, you will get the notification and click it to download.
Thanks for your patience.
We have seen several stability issues that happens only on the new Macbook Pro with touchbar. These issues include edit pagesetup crash, crash when new from a template from welcomescreen, etc.
We are working on a hotfix to address the issues on the new Macbook model.
Wei
Wei Ma
AutoCAD QA Manager
Replies (19)
Message 2 of 20
Tom_Janus
With y new touchbar mac with Sierra autocad for mac 2017 crashes every time I close a drawing whether I make no changes or close after saving the drawing.
--TJ
Message 3 of 20
I am experiencing the errors you are describing. Problems occurring, and causing ACAD to crash when entering edit page setup, even in an entirely new drawing.
When do you expect the hotfix to be ready ?
Message 4 of 20
Tom_Janus
I've gone back to 2016, much better but still have occasional crashes.
TJ
Tom Janus Inc.
917.860.9332
[email protected]
alt: [email protected]
Message 5 of 20
I am experiencing the same issues in ACAD 2016, unfortunately.
When can we expect a hotfix?
Message 6 of 20
wei503
Hi @Tom_Janus
Could you please send me the drawing that crashes at close?
My email: [email protected]
Wei
Wei Ma
AutoCAD QA Manager
Message 7 of 20
When I try to check for the update my notification tells me that it is up to date.  My computer still crashes when I try and use page manager. I have Autocad  2016 and I have the Mac touch bar.
Message 8 of 20
maxim_k
The Hotfix was released only for AutoCAD 2017, but you have the same problem in 2016 version.
Looks like we need to wait for the response from developers.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 20
Hi
Have the new mac with touch bar and running 2017
Some times just selecting an object is difficult unless I zoom in and out.
Also Purge and - Purge don't seem to work , No combo box appears
It gives me an option for All but then nothing seems to happen
Message 10 of 20
maxim_k
Welcome to Autodesk Forums!
I'm not sure about object selection, but PURGE command works fine on my side.
In AutoCAD for Mac PURGE command doesn't have dialog box interface - only command line, so you need manually select options inside PURGE command to work with.
Look at the command prompt and select options and response to AutoCAD prompts.
For example when you want to use ALL option in PURGE command, you need to answer to the additional prompts from AutoCAD:
Command: PU
PURGE
Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/Orphaned data/All]: all
Enter name(s) to purge <*>: <- here you need to hit Return
Verify each name to be purged? [Yes/No] <Y>: n  <- here you need type n and hit Return
Than the command should work and you will see prompts about purged objects (if any).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 20
HI
Thanks for reply
Selection is a little weird . every now and again it just will not let me pick . if I zoom in and out , then it will work. If I pick another object and then go back to the one I was having trouble with. It works. Weird.
Purge.
I went through the prompts, All, <*> and N a few times, But nothing seems to happen.
I asked one of my colleagues who has recently put 17 on his standard mac pro and his Purged fine.
I wonder , can I do some sort of Repair?
Gary
Message 12 of 20
HI
Thanks for reply
Purge.
Gary
Message 13 of 20
maxim_k
What do you see in the command window on your Mac when you are trying to use PURGE command? From the time when you enter PURGE to the time when Command: will appear again.
Can you attach unpurged drawing here? I can look at it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 20
Hey!
My problem is, when I go to page setup, auto cad 2017 crashed down. I have a new MacBook Pro with old touch bar. So I know, there is an issue with this one. But when I want to install the hot fix, my computer says; that auto cad isn't closed, so I CAN NOT install this hot fix... What can I do? Because I don't know what to do anymore...
Kind regards,
Yasemina
Message 15 of 20
maxim_k
Hi Yasemina,
Before starting Hotfix installation you need to close AutoCAD completely with QUIT command, then restart your Mac.
You can also close AutoCAD during Hotfix installation - you yourself posted screenshots of the alerts where you can close AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 20
Hello, I am having this problem and cant seem to fix it. I have macbook pro with touch bar and the programme crashes after clicking OK on the the page setup manager. I have tried installing several different versions of autocad and it occurs every time without fail in all versions. Please help!
Message 17 of 20
maxim_k
Look at my answer here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/autocad-mac-2015-page-setup-crash/td-p/6847107
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 20
I'm using AutoCad 2015 on the new MacBook Pro with touchbar. Is there also a hotfix for this version? Because when I open edit page setup, AutoCad crashes every time.
Thanks!
Bjorn
Message 19 of 20
pendean
Community Legend
Community Legend
Are you running a MacOS version newer than the system requirements for R20154Mac? Then that's your problem https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
Updates can be found with a websearch if you want to explore the help files for each https://www.google.com/#newwindow=1&q=autocad+for+mac+2015+updates
Message 20 of 20
So how can I solve it?
