AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Autocad for Mac not working
3 REPLIES 3
552 Views, 3 Replies
I downloaded Autocad 2018 for Mac from Autodesk website and installed. The Autocad opens fine, but as soon as I try opening a file (in this case I am trying .dwg file), the system hangs up (unheard in Mac world).
The file is not corrupted as I can open the same file through Autocad in PC (windows 10). Also I can open the same file using Fusion 360 in my Mac. My Mac is new and with latest and greatest hardware, so can't think of hardware as an issue here.
Can anybody guide, what could be going wrong here. Is Autocad for Mac not successfully working? and any reason why it is not put up in Apple App Store even though Fusion 360 is available in Apple App Store.
Thanks!!
3 REPLIES 3
maxim_k
Are you able to create new drawing with AutoCAD?
Can you open any other DWG file then you mentioned in your post?
BTW - Fusion 360 for Mac opens (import) DWG files by pushing them through the Cloud Translation Process, so conversion process take place on Autodesk servers, but not on your Mac
AutoCAD for Mac works fine for most users and it is able to open drawings, created in AutoCAD on PC.
AutoCAD doesn't appears in Mac app Store, for several reasons. For example, because it is not sandboxed application.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Post a DWG file from a Windows PC that you cannot open, let those with your MAC setup repeat the test.
Also remind everyone what your MacOS version is please.
I also face the same problem while installing the AutoCAD software on my computer. Then I solve my problem from outlook support. You can also take help from the support team.
