AutoCAD for MAC “application not responding” and can’t sign in
beaubo
Message 1 of 17
beaubo
Are any other MAC users having issues with their AutoCAD LT for Mac? I have a brand new Mac laptop and every month or so AutoCAD freezes and won't let me sign in or open the program. I've worked with multiple Autodesk technicians, who usually get it to work but the problem keeps persisting (usually after a new Mac update...)
I’ve tried:
-uninstalling/ reinstalling AutoCAD
-rebooting in safe mode
-run permission repair on disk utility
-resetting the subscription license for MacOS
Usually after a couple days I’ll get an Autodesk technician who can fix the issue, but it keeps returning about a month later and freezing again.
Replies (16)
Message 2 of 17
maxim_k
Welcome to Autodesk Forums!
Hi Beau,
Can you describe or reproduce the steps that a Autodesk technician is taking to resolve the issue?
and - please, do not double post on the Forum.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 17
pendean
Community Legend
Community Legend
... also list your LT year version and your MacOS please.
Message 4 of 17
john.vellek
Hi @beaubo,
I looked up your prior cases.  It appears in one case it was determined that you were actually having some OS issues.  In the other case it appeared that your user profile had become corrupted. Please tell me the exact version of AutoCAD you are currently using by typing ABOUT at the AutoCAD command line. Please also tell me your OS version.
When you experience this occasional problem, are you connected or disconnected from the Internet?  When this happens nexxt, can you check the status of ADSSO in the activity monitor?
John Vellek
Message 5 of 17
john.vellek
Hi @beaubo,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
Message 6 of 17
I am having the same issue. How can it be resolved?
Message 7 of 17
maxim_k
Hi Joseph,
Please specify your AutoCAD version, macOS version and license type (educational, subscription...)
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 17
AutoCAD 2019, Mac OSX, and educational version.
Message 9 of 17
maxim_k
Which macOS? 10.12, 10.13 or 10.14?
Do you have this issue just after installation or it appeared suddenly after you were able to use AutoCAD for some time?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 17
maxim_k
Have you managed to activate AutoCAD as described here:
https://forums.autodesk.com/t5/installation-licensing/steps-for-setting-up-student-software/m-p/6825...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 17
Yes it previously worked for a couple of weeks but yesterday started not responding or opening so I tried uninstalling and reinstalling but the issue is still the same.
Message 12 of 17
Yes I have followed all those steps the stage that it doesn't respond is once I've opened the application and click single user to try and log in the application just closes and says not responding.
Message 13 of 17
maxim_k
Can you show screenshot of what you see, when you cannot sign in?
Have you tried to use "enter serial number" instead of signing in?
If AutoCAD license information on your Mac was corrupted for some reason, you may also try to clean uninstall (if you have not tried this way):
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
before installing AutoCAD again.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 17
Thankyou very much for your help I have resolved the issue.
Message 15 of 17
maxim_k
Can you describe how it was resolved?
This will help other users with the same issue.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 17
I selected enter serial number instead of single user then updated then it allowed me to also update the application which has meant it has stopped happening.
Message 17 of 17
maxim_k
Thank you for the clarification.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
