hi, i've install the student versin of autocad 2013 for mac but my toolbar and menu's bar doesn't show up!
Here is a screen shot:
Solved by maxim_k. Go to Solution.
Could you check whether MenuGroup.cui, PopMenuRoot.cui, Workflow.cui files are in place inside "~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/Support" folder?
Maxim
The files are inside Library folder in your home folder, but by default it is HIDDEN, to reach it you have to hold Option key and Use the “Go” Menu in Finder ( http://osxdaily.com/2011/07/22/access-user-library-folder-in-os-x-lion/ ).
Could you find the files now?
Maxim
This explains everything (I mean absence of the menu and tool sets in your case).
This could be permissions problem, because AutoCAD on first start copies these files to user support folder from inside application folder (/Applications/Autodesk/AutoCAD 2012/AutoCAD.app/Contents/Resources), but in your case AutoCAD can not do this.
You can try to "Reset Application Options" from Application tab of "Application Preferences" dialog (menu AutoCAD -> Preferences, if you don't have such menu - with command PREF)
If this doesn't help - try to solve the problem by repairing permissions on Library folder in your home folder.
You can also try to manually copy CUI files to "~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/Support", but I'm not sure if it exists on your Mac - if you have permissions problems, then this folder may not be in place at all.
Maxim
I had to manually copy CUI files to that folder and it solve the problem!!!
Tank you ver much!! Big help!
JPV
Hi JPV,
Glad I can help you, but:
One moment, please.
Could you assist me in further investigation of this issue?
If yes - could you try to make some customization to ToolSets or Menus with CUI command?
Does AutoCAD allow this and saves changes you made?
Thanks in advance,
Maxim
Thanks for info
Maxim
Hi Maxim -
I am having the same problem that you helped Jorge with, but I don't have the necessary .cui files in my applications folder in order to manually move them. How does one get those files?
-Andi
Hi Andi,
You can try the solution form this place:
http://upandready.typepad.com/up_and_ready/2011/10/autocad-2012-mac-autocad-error-aborting.html
It is about AC 2012 and in the case described there the program terminates abnormally, but the author offers a solution to something similar to your case.
Try to download attached ZIP archive and extract Autodesk folder from this archive into /users/YOUR-USERNAME/Library folder.
The folders and files structure in attached archive is exactly the same, that should be created on the first run of AutoCAD 2013 for Mac.
But I have to say: it seems to me - definitely on your MAC is something wrong with permissions.
Maxim
Hey,
I'm on Autocad LT 2013 with OSX Mountain Lion
I have the same issue on screen, although all the CUI files are (and were) where they should be.
I tried to reset the tool bar (wich is empty of any icons) and it did reset the settings (Tools<Customise<Interface CUI), but not the display(Toolbar) wich is still empty.
I now lost my personal settings AND didn't get the display back 🙂 What a wonderfull day !
I would be glad if anyone can help who knows what may be happening, ... before i give up and reinstall the application ! LOL
Thank you
Ben
Ok,
I have no idea how, but it reapeared.
I did try to quit ant relaunch before but that time was the good one.
You can still tell me if you know what was wrong with it.
