AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Autocad 2013 for MAC (student version) - TOOLBAR, MENU BAR DOES NOT APPEAR
35 REPLIES 35
Message 1 of 36
16038 Views, 35 Replies
hi, i've install the student versin of autocad 2013 for mac but my toolbar and menu's bar doesn't show up!
Here is a screen shot:
Tags (1)
35 REPLIES 35
Message 21 of 36
maxim_k
I have no idea at all. I thin In some case AutoCAD can not access support files on your Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 22 of 36
Ok, thanks anyway Maxim!
Message 23 of 36
in reply to: maxim_k
I need your help! I have Autocad for Mac 2013 student version.The software on screen appears the same as on the first post above. I followed your instruction MenuGroup.cui, PopMenuRoot.cui, Workflow.cui files are in place inside "~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/Support" folder. However I do not have them when I start up the software, I mean I do not see them and i can't use them. Could you help me if possible.
Thans in advance.
Message 24 of 36
maxim_k
Welcome to the Autodesk Forums!
As first attempt to solve your problem:
Create new user account with administrative privileges, log into in and start AutoCAD.
Do you see all interface elements?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 25 of 36
HI,
thank you for your reply. Unfortunately I did what you explained, but it is still the same, nothing change. Any other idea to solve this problem?
Thank you
Message 26 of 36
maxim_k
To say true, I newer faced with such problem, so I don't know the exact steps for solution.
But If you have the same results from different account, then there could be permissions problems on your Mac on System level.
But just in case: could you verify version of AutoCAD installed on your Mac? At the command prompt type _vernum and hit Return:
Command: _vernum
_VERNUM = "G.55.M.108" (read only)
Is it the same as mine?
have you also tried to Reset application settings from Application tab of AutoCAD Options?
BTW: you can delete additional account which you have created at my request, if you don't need it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 27 of 36
This is the result after all attempts:
I am so dissapointed of what happened. Have you got any other idea, or at least who else may I ask for help?
Thank you
Message 28 of 36
Message 29 of 36
maxim_k
About _vernum command: you have to type it at the AutoCAD's command prompt, but not in the Terminal app. But it looks like it doesn't matter now, because:
Sorry, but now I don't understand what you asking about. Your screenshots clearly shows Menubar and Toollbar (Tool Sets palette).
So everything goes fine since now?
Could you explain?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 30 of 36
Hi, sorry for the confusion. Seems like its working now. Since I changed with the new user account! Then I though I still have mssing some command like " workspace switching", but then I fount it does not exist at all, as  Mac version is much more different from PC, to what I am used to see it. Thanks for your help!
Message 31 of 36
maxim_k
So starting AutoCAD in new account solve your problem? Is it correct?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 32 of 36
Thank you manually copying the files you suggested did get me the tool bars on the side but not the menu bar across the top, any further ideas?  Other files I need to copy?  thanks.
Message 33 of 36
maxim_k
Welcome to Autodesk Forums!
Have you tried the solution with another user account (look for it some posts above)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 34 of 36
I have tried:
Verify and Fix disk permissions
Completely un-installed and reinstalled ACad
I am logged in as an administrator
I copied the suggested files into the suggested library folder.
I reset application options, which made the tool bar disappear and removes the manually installed CUI files.
Manually reinstalled CUI files and the tool bar came back but no menu.
The one thing that I did not get any results from is typing " _vernum", As soon as i type it and hit enter, just get a blank command line.
Any other ideas would be appreciated. Thank you. ej
Message 35 of 36
maxim_k
You did not answer my question:
When you log as another user on your Mac (create temporary account with admin privileges, log in with this account) - do you have the same issue with Toolsets and menu?
As about "_vernum" command results: it appears you have to expand Command line window (with F2 key) in order to be able to see command history.
BTW - what OS do you have on your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 36 of 36
I was not successful creating another user, but I was successful by manually adding the workspace,workflow,menu group and popmenugroup cui's to the suggested folder and that took care of the issue. thank you for pointing me in the right direction. have a good day. ej
btw did have the same version as you( confirmed through _vernum)
and os is X 10.8.5.
Technology Administrators
