I have a drawing that has lots of hatches with different shapes. If I select 2 hatches or more, on my Properties Inspector the area will show multiple values (Area: Multiple Value). Before, it used to add the total selected area. How can I activate this again? I don't want to calculate it by myself of use Area>add Area>Object.
The previous one was much faster.
Solved by maxim_k. Go to Solution.
Welcome to Autodesk Forums!
In the Properties palette at the top of the properties list change to "All" instead of "Essentials":
You will see Comulative area at the bottom.
Maxim
