2020 Version has a memory leak or something
Message 1 of 8
My computer goes into overdrive and any command has a pause of like 2 seconds before I can pick whatever I need to pick. Not sure what is going on. Please fix it, I am going back to 2019. The same drawing in 2019 has zero problems.
Russell
Replies (7)
Message 2 of 8
betazero
Having the same problem....
Message 3 of 8
pendean
Community Legend
Community Legend
Both of you need to report it to Autodesk over here if you want it to get noticed and addressed http://download.autodesk.com/us/support/report_a_bug.html
These forums are not actively monitored for bug reporting.
Message 4 of 8
maxim_k
Hi @Anonymous and @betazero
What if you will remove all blocks from “Recent” tab of new Blocks palette?
Do the delays go away?
You may also try to Reset AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 8
betazero
Wow yes that did it!
Once again Maxim to the rescue!! I removed the recent blocks and closed that palette. Will it keep populating with recent blocks if it is closed? I tried closing it first but it wasn't until I remove the recent blocks that it went back to normal.
Message 6 of 8
betazero
Ok I would love to add this to the bug reporter but the list of software to report does not include Autocad or Autocad for Mac. Where do I post a bug report on the bug reporter? 🙂
Message 7 of 8
maxim_k
It will be populated even when closed, but you can set system variable BLOCKMRULIST =0 and it will not be populated in any case.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 8
maxim_k
I already reported about this bug.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
