2020 Version has a memory leak or something
No aplicable
My computer goes into overdrive and any command has a pause of like 2 seconds before I can pick whatever I need to pick. Not sure what is going on. Please fix it, I am going back to 2019. The same drawing in 2019 has zero problems.
Russell
0 Me gusta
Responder
Soluciones aceptadas (1)
1.141 Vistas
7 Respuestas
Respuestas (7)
betazero
Having the same problem....
0 Me gusta
pendean
Community Legend
Community Legend
Both of you need to report it to Autodesk over here if you want it to get noticed and addressed http://download.autodesk.com/us/support/report_a_bug.html
These forums are not actively monitored for bug reporting.
0 Me gusta
maxim_k
Solución aceptada
Hi @Anonymous and @betazero
What if you will remove all blocks from “Recent” tab of new Blocks palette?
Do the delays go away?
You may also try to Reset AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
betazero
Wow yes that did it!
Once again Maxim to the rescue!! I removed the recent blocks and closed that palette. Will it keep populating with recent blocks if it is closed? I tried closing it first but it wasn't until I remove the recent blocks that it went back to normal.
0 Me gusta
betazero
Ok I would love to add this to the bug reporter but the list of software to report does not include Autocad or Autocad for Mac. Where do I post a bug report on the bug reporter? :cara_con_una_leve_sonrisa:
0 Me gusta
maxim_k
It will be populated even when closed, but you can set system variable BLOCKMRULIST =0 and it will not be populated in any case.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
I already reported about this bug.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
