Wire Surfer Instant Surfing
Can the wire source and destination surfer be chnaged so that the source and destinatino arrows are hyperllinked? i.e. a left clcik on an arrow will take you directly to the destination and vice-versa. A right click will still bring up the normal marking menu options.
Even when wires are daisy chained with the same signal code this will work as the sort order is defined in the project and drawing properties
3 Comments
ccad2509
this feature is standard on eplan/wscad/igexao so it’s a standard feature the market uses as we all know Autodesk does not go the way the market goes it decides to ignore what all the other products common functionality and decide to go its own way so look out Autodesk will reinvent the wheel with something that will only half work or better still something you didn't ask for be different from the rest don’t put functionality in which is clearly devlope from multiple sources as an agreed common function this is the acade way
miles.nicholson
I know its a standard feature on some other packages. Please vote for the feature if you would like to see it in AutoCAD Electrical. Cheers
It would also be nice if it links to a different drawing, just open another tab instead of replacing the current tab of the drawing I'm working on
