Using the Layout (paper space) for the Title Block ONLY
We been using ACADE in a way that EACH schematic, wiring diagram, report, drawing list, etc is in one drawing file in the model space, and each file has one Paper Space (Layout) that will be located the title block ONLY.  This way we can use all the benefits of using the Layout such as Paper size, Viewport, etc, specially the Panel Layout that helps to have more than one layout to show different viewports of the panels and differnt zooms.
So far all the electrical tools work fine except for some minor issues that will be helpful if it can be implemented.
Using the Sheet (%S value) of The Project-Wise Update will resequence all the drawings but the drawings that has more than one layout will use the same sheet number.
Using Publish to PDF/DWF/DWFx, it only has the option to select First layout tab, so we have to added manually the missed layout to the list.
The Drawing List Report ONLY get what is in the Drawing Properties and the Project Description, but not from the title block.
