Swap / Update Multi-pole Blocks
It would be good if the Swap/ Update Block command could update a multipole block insertion such as 3 phase circuit breaker. It could easily work by checking whether a dashed link line connects to multiple devices and prompt to update or swap out in order the linked items
1 Comment
It would also be good if when placing the multipoe block and checking the repeat check box, it would insert the multipole symbol rather than just duplicates of the original symbol in the command.
