same component tag for multiple devices but separated by installation/location
having to name every component with a unique tag can get take up a lot of space. For example LT-1, LT-2, LT-3, etc. (obviously some component tags are larger than just "LT")
If I am able to name multiple components LT and separate it from each by using the Installation and/or location codes, it will save a lot of space and eliminate the annoying "-#s".
2 Comments
You already can do this in Project Properties. It will let you use use the same tag name based with location you have given to the part.
ccad2509
#lockdownbored
this is why autodesk state an IEC style numbering system because they cant do proper IEC style numbering
location was change back in 2010 to mounting location and they haven't bothered to update the software
