Hi Experts,
While generating "From/To" Reports from AutoCAD Electrical 2013; if we sort the report using primary sort & secondary sort (fields) as COMP/ PIN values (containing values like 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, ... so on ). By doing same, Sequence in report follows order: 1, 11, 12, 13, ...19, 2, 20, 21, 22, ...29, 3, 30, ... so on instead of which preferred one is : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, ...so on. Kindly guide to get same in preferred order if solution already available for same.
Thanks in advance...
Mi**** Thakkar
