Problem:
When running a schematic BOM there is no option to include "Panel" components. When running a panel BOM there is an option to include schematic components but the sheet references will be for the panel components only. Most companies I work with prefer the sheet referecnce to point to the component in the schematic. To get a complete BOM with correct sheet numbers a schematic and panel has to be run.
Solution:
Add option to include panel only components to schematic BOM. This will enable components such as din rail, trunking etc to be included and will result in a complete BOM with accurate sheet references in one report.
