There is a Circuit. The connections between the connectors are made using the "Fan In Source" and "Fan Out Destination" tools. Copy the Circuit and in the dialog box "Copied Source Single Arrow" need to add button "Increase Signal Code”.
![1.png 1.png](https://forums.autodesk.com/t5/image/serverpage/image-id/202819iCF7C10706CB59BE4/image-size/original?v=mpbl-1&px=-1)
It should work similarly to "Increase terminal number" in the dialog box “Copy Circuit Options”.
![2.png 2.png](https://forums.autodesk.com/t5/image/serverpage/image-id/202821i34DA8F522ABDD927/image-size/original?v=mpbl-1&px=-1)
