Multi level terminals and export to / import from spreadsheet
The export to and import from spreadsheet function does not work with multi level terminals.
If I have a terminal strip of multi level terminals and the terminals are numbered using the renumber terminal strip function in the terminal strip editor and than build the panel foot print for this terminal strip everything looks good.
If I then do an export to spreadsheet (General or Panel terminals it does not matter which), the spreadsheet report only lists the top most level numbers of the multi level terminals.
If I import this spread sheet back into the electrical project all panel footprint multi level terminals are renumbered so the lower levels now share numbers with the top most level of the multi level terminal.
This needs to be fixed.
I am running AutoCAD Electrical 2014
