I can't find a way to do this, so I'm asking for it here. There needs to be a way to limit the number of connections to a pin similar to a terminal. In my industry we use a lot of complex relays that have Phoenix style terminals for connections. But since this relay is modeled as a whole, these are pins, not terminals. I need to be able to prevent the software from trying to land more than one wire on these. Of course it can be handled manually, and often as not the way we use these there is only one connection anyway, but to prevent errors from getting out, a limit would be nice.
Regular relay pins (threaded studs) can take several connections if needed, so this needs to be an individual pin or component level thing, not a drawing or project wide thing.
