AECHILDLOCUPDATE - missing some functionality
I transferred this idea from the discussion forum http://forums.autodesk.com/t5/autocad-electrical-general/aechildlocupdate-missing-some-functionality...
I use the AECHILDLOCUPDATE command regularly as its great for updating panel or child symbols with the schematic parent values.
However its a bit outdated and missing a few things I was hoping someone out there might have some suggestions or alternatives
       1.   I haven't found any API info or API help on this command.
       2.   I would like the dialogue box to default to having both the Rating Values & Manufacture Values checked off. does anyone no if there is a lisp or DCL for this  command that could be modified. Ideally this would be a command prompt type command to bypass dialog box altogether.
       3.   The command in theory should also function for updating symbols of different WDTYPE. for example PID or one line symbols.
Another issue is that you cannot process Installation and Location values if you have your project set for Combined Installation/Location Tag Mode.  You have to temporarily disable Combined Installation/Location Tag Mode, run the child update, and then enable Combined Installation/Location Tag Mode again.
1 Comment
t_chaws
Thank you for posting this Idea. We have added your idea to our research bucket and we will be looking into your suggestion for future releases.
Keep Posting more ideas and dont forget to support your community mates by giving them kudos to push their ideas forward!
Best Regards,
AutoCAD Electrical Team
